Finnish offroad gps challenge cup for year 2010.
As it has published year includes four races.
26-28.2. Offivarusteen Talvieksytys 2010 (Askola)
14-16.5. Paratiisi Offi 2010 (Oulainen)
24-25.7. TML Trophy 2010 (Juuka)
02-03.10. Himalaja 24h (Near Mikkeli)
I'm sorry for delay to publish english rules, but those are under work... Mostly rules are same than in year 2009, but couple changes. I'm writing those changes here by my bad translation:)
- Now on if you are not in present in protest time and there has been systematic mistake or any mistake which cause result position change, that can be corrected within 5 days. You need to send protest where you explain what was that mistake to head of race and to email: officup@gmail.com. Race results are not corrected, but cup-points can be corrected.
- Every seats has to be protected by car body *or* by roll cage. This is mainly done because it looks so bad when people are sitting for example back of C303 which is without rear cabinet or in some other cars where back of cab is taken / cutted off.
- In car have to be towing points and winch hook from which rope/cable/hook can't detach by mistake.
- In class original shortening frame is forbidden.
- Touching in the control point pictures must be to the fixed parts of the car. Only the doors in the side of the car may be used to increase the car dimensions. Other doors and hatches of the car may not be used to improve the dimensions,and the touch to these is counted only if they are clearly and completely closed. These hatches can be opened, so the car can display the identity in the control point pictures better. Hatches and doors should be hinged only on one of the edges, the doors in the side of the car on the front edge.
Finnish GPS challenge cup 2010 rules / timetable
Rules for season 2010
http://www.4x4cup.com/tiedostot/saannot ... -01-19.pdf
Change log: Changes from rules 2009 -> 2010
- changed the year in the main title 2009 -> 2010
- added new chapter 1.1 Results correction to the table of contents
- header update ("version number") 20.12.2008 -> 15.12.2009
+ added whole new chapter 1.1 Results correction to the rules
- chapter 4 GENERAL REQUIREMENTS removed the last bullet from Common rules for all competition classes -list: "All doors and hatches should only be hinged on one side" (see the text added to chapter 8.1)
+ chapter 4.3 Safety added two sentences:
+ The seats for all competitors in the car must be located fully inside the protective car body and/or the roll cage.
+ Winch hooks and towing points must not allow the tow ropes etc. to become loose unintentionally.
+ chapter 5.1 Original added "Shortening the frame of the car is not allowed."
+ chapter 8.1 Specific regulations for photographing added the following:
+ Touching in the control point pictures must be to the fixed parts of the car. Only the doors in the side of the car may be used to increase the car dimensions. Other doors and hatches may not be used to improve dimensions, and a touch to these is counted only if they are clearly and completely closed. However, these hatches can be opened to allow the car to be identified better in the control point pictures. Hatches and doors should be hinged only on one of the edges, the doors in the side of the car on the front edge.
- chapter 12 added competition series e-mail address: officup@gmail.com
