Warn winch?
Warn winch?
Någon som kan säga vilken modell på winch detta är?
En Warn är det iaf, så mycket vet jag.
[URL=http://s480.photobucket.com/user/R ... .jpg[/img][/url]
Re: Warn winch?
Hittade den!
WARN 9.5xp
Fast, powerful and reliable - for extreme conditions
The 9.5xp Extreme Performance winch is designed to offer the highest performance in the harshest conditions. From its fast line speeds and strong 4,310 kg pull rating, to its extreme-duty sealing and contactor control, the 9.5xp is the winch you want when the trail gets tough.
Series-wound winch motor is powerful and reliable
Extreme-duty winch sealing. Enables superior water resistance
Exclusive brake design. Provides superior operator control when winching
Extended-duty control pack delivers long duty cycle to help you tackle the most demanding pulls
3-stage planetary geartrain for fast, smooth, reliable operation
Remote-mount control box allows for a variety of mounting configurations
Includes both corded and wireless winch controls
High-gloss, chip-resistant powder-coated finish provides superior corrosion resistance
100' (30m) of steel
9.5XP SPECS/PART NUMBER
Winch model: 9.5xp
Part number: 86500 (wire rope, CE)
Rated line pull: 9,500 lbs., (4310 kgs.) single-line
Motor: 12V 6 hp (4.48kw), High output parallel series wound
Electrical controls: Contactor
Remote controls: Remote switch, 12' (3.7m) lead and
Geartrain: 3-stage planetary
Gear ratio: 156:1
Clutch (freespooling): Sliding ring gear
Brake: Automatic direct drive cone
Rope: Steel - 100', 5/16" diameter (30m, 8mm diam.)
Fairlead: roller fairlead
Recommended battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72" (1.83m)
Finish: High-gloss powder coat over primer undercoating
Drum diameter/Length: 2.5"/9.0" (6.4cm/23cm)
Weight: 87 lbs. (39.5 kgs)
12V DC PERFORMANCE SPECS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 38 (11.6) 70 amps 1/9500 (4313)
2000 (910) 16.8 (5.1) 175 amps 2/8650 (3927)
4000 (1810) 12.8 (3.9) 262 amps 3/7920 (3595)
6000 (2720) 10.1 (3.1) 335 amps 4/7400 (3359)
8000 (3630) 8.8 (2.7) 425 amps 5/6940 (3150)
9500 (4310) 7.6 (2.3) 480 amps
Above performance specs are based on first layer of drum
Winch Dimensions: 22.7" L. x 6.3" D. x 7.7" H.
(577mm L. x 160mm D. x 196mm H.)
Mounting Bolt Pattern: 10.0" x 4.5" (254mm x 114.3mm)
WARN 9.5xp
100' (30m) of steel
Winch model: 9.5xp
Gear ratio: 156:1
Line Pull
layer/Lbs(Kgs.)
Re: Warn winch?
jag tror det är en mycket äldre winch än en 0,5 xp , jag har en sån å den tycker jag inte ser ut som din
Patrolen
Patrolen
Re: Warn winch?
Troligen är det Warn M5000 från 80 talet,går nog att spåra med hjälp av tillv.nr Ring till Rindab som är generalagent/Erik
Re: Warn winch?
Tror det fanns en modell som hette m4500 också,oavsett är det en ganska svag winch som det är svårt att få tag i reservdelar till och då speciellt motorn
Re: Warn winch?
Tackar för all info.. Ska ringa Rindab under veckan och höra med dom!
Tack igen alla!
Tack igen alla!
